I’ve recently fitted a new engine. I’ve used the same gearbox as last time as it was all fine. No crunching and went through the gears nicely. When I built the engine I didn’t touch the gearbox as it was all ok when in the car.
After fitting the new engine I’m now struggling to get into 2nd gear when downshifting from 3rd. It crunches at higher speed. The car is a mk1 and I have made a bracket to hold the Rod change linkage into a mk1 round tunnel. The previous engine has this and I had no problems.
I have tried to move the bracket to find the fault and create different angles, but no luck. However, I angled the Rod change shifter so it was lower on one side, just to see what it would do. This made the crunching worse, even at a low speed, it would crunch from 3rd to 2nd. So I positioned the linkage to angle straight again and now the 2nd gear will go in…no crunching…but at more higher speeds, it still crunches.
also, I’ve sat with the car stationary and revved the engine to around 3k rpm and gone down from 3rd to 2nd and no crunch…..
when the engine is switched off and the car stationary, it is sometimes difficult to get the gears, almost like something is stopping it going in. Almost like it is hitting something. If I try it again, it goes in ok. I’ve used molegrips on the linkage and tried to engage gears with that instead of the gearstick and it didn’t put up any resistance and no problems going through the gears.
any ideas what this could be? If it was the synchro in 2nd gear it would crunch when I revved the car up and shifted down from 3rd to 2nd while the car was stationary?
any help appreciated. Thanks.
