Thought I would try and post whilst the forum was working.
As above but I have removed and checked the stalk and all appears working - assume it is just an earth switch and the wipers/pump have their own ignition live feed?. They were working previously but have done quite a lot of engine and wiring work since then so have clearly done something to stop them working!!
I have checked all fuses and even the connectors on the hot side and they are all live so no issue with the fuses. But there does not appear to be any live to the pump or wiper motor - I have removed the connectors and could not find a live in the wiper motor connector block.
I have the Haynes manual so will have a look at the wiring diagrams but suspect some of you will have had a similar issue and if so what was it or what do you recommend to track down.
Seems odd that neither the pump or wipers work and no live in the wiper motor connector block? Open to thoughts
