850 Crankshaft - Would A Damper Help It To Live With High Revs?
10 replies to this topic
#1 NDT
NDT
  • 186 posts
Posted Yesterday, 03:45 PM
850 cranks (particularly the thin nose ones) supposedly fail with high rpm use.
This is despite them having a relative short stroke and a nice overlap between the big end pins and mains, which should make them relatively stiff.
Does anyone know whether a decent crankshaft damper improves things? I don't think these were fitted on the 850?
#2 DeadSquare
DeadSquare
  • 3,122 posts
Posted Yesterday, 04:35 PM
"High rpm use" is a bit vague;  would that be sustained of peak ?
In 1960, with Formula Junior double valve springs, early thin tail cranks were revving to 7,000 rpm through the gears, without a damper.
Even with a damper, a sustained 5,500 rpm would break 1100 cranks at 70mph on motorways, if an engine and box were dropped into a Mini without changing the 4.1  Diff to accommodate the 10" wheels.
Downton used to fit the 997 Cooper damper to their 850 racing engines with Tuftrided cranks, and I often got the needle past the 8,000 mark.
#3 Spider
  • 14,946 posts
Posted Yesterday, 07:26 PM
My 850 experience is quite limited.
Do you know where they fail ? This might show if their failure is from torsional vibrations or simply being too spindly.
The correct Damper can't hurt, but be aware, for conventional rubber mounted dampers, they are 'tuned' to suit a particular bottom end, they are not 'one size fits all'. I'd suggest if you were to try one, go for a fluid filled type (I think the KAD ones are) and that would negate the need for tuning it.
#4 NDT
NDT
  • 186 posts
Posted Yesterday, 08:59 PM
That's a great question.
In reality, it's for a road car, so we're not talking sustained high rpm use, just the occasional thrash to high revs.
I've just got my freshly painted 62 shell back and want to get the powertrain sorted.
I've got a 1275 engine ready to rebuild, but I have an urge to see how far the original 850 could be taken, maybe with a supercharger.
I know the 1275 option will be much much easier and cheaper, while giving me more power, but keeping the original engine and box could be much cooler.
#5 NDT
NDT
  • 186 posts
Posted Yesterday, 09:00 PM
My 850 experience is close to non-existent. I don't know where they fail - good question.
And a good point about damper tuning.
#6 ACDodd
ACDodd
  • Mini Docs
  • 2,752 posts
Posted Yesterday, 10:03 PM
Spider is right here, the conventional dampers are tuned to work at the rpm you most need the effect, so fitting one from a different engine is not likely to achieve the effect you want, however after further reading it’s likely you won’t really need one for the use you intend.
Ac
#7 Cooperman
  • 23,303 posts
Posted Today, 10:59 AM
If you fit a supercharger, then you won’t need high revs.
I am old and have used 850 Minis with modified engines in competition. With rally engines giving maybe 55-ish bhp they would rev to 6,500 rpm regularly with no problem. We didn’t fit different crank pulleys.
For full race 850’s I seem to remember that a special crank was available, but I could not have afforded one back then on apprentice wages!
#8 NDT
NDT
  • 186 posts
Posted Today, 02:32 PM
Ac
Thanks AC - that's really helpful.
#9 NDT
NDT
  • 186 posts
Posted Today, 02:33 PM
Great, thanks.
I will get the engine out and inspect it at the weekend and start planning...
#10 Cooperman
  • 23,303 posts
Posted Today, 03:29 PM
I once gave a lot of thought to fitting a Shorrock supercharger on my 850 Mini. I did the calculations, but then I got a much better paying job and bought myself a brand new 998 Cooper instead. That was in 1964!
#11 DeadSquare
DeadSquare
  • 3,122 posts
Posted Today, 06:55 PM
I ran my Shorrock on a host of A Series engines and the one that responded best was the 1100, easily topping a 1275 S.
An 850 needed MG 1100 inlet valves and Cam number 948.
For a brief period, Shorrock sold a very good inlet manifold, which meant replacing the exhaust manifold, but in those days, a 3 branch S exhaust was easy to buy and not too expensive.
