Brake Servo Air Filter
5 replies to this topic
#1 sparkymae
sparkymae
  • 128 posts
  • Local Club: None
Posted 29 May 2025 - 12:03 PM
Hi all. On page 9-18 in the Haynes Manual there is this little,( they call it a air filter) filter in the small boot. Is there a part number for this and do you replace this from time to time or just leave it alone. 69-2001 Haynes. My car is a 1990 998cc manual.  It's on the vacuum servo rod.    Thanks
#2 stoneface
stoneface
  • 386 posts
Posted 29 May 2025 - 01:00 PM
Not got a haines manual to look at, but I'm pretty sure this is the foam filter shown in the repair kit
https://www.minispar...9-servo-lk10125
Edited by stoneface, 29 May 2025 - 01:15 PM.
#3 DeadSquare
DeadSquare
  • 3,133 posts
Posted 29 May 2025 - 01:09 PM
I have seen servos mounted under the wing, with "Fossilised" filter, that still worked.
#4 Ethel
  • 25,990 posts
Posted 29 May 2025 - 02:16 PM
There isn't any airflow to  speak of, just enough to establish atmospheric pressure behind the diaphragm when you brake. If it's just the filter you need don't see why you couldn't fashion your own from a bit of foam for a hoover or fish tank.
#5 Spider
  • 14,964 posts
Posted 29 May 2025 - 07:10 PM
The factory recommended period for that filter change out is 24,000 miles, however if it's regularly used in dusty conditions, this may need doing sooner.
#6 sledgehammer
sledgehammer
  • 3,100 posts
Posted 29 May 2025 - 07:23 PM
I use a vacuum foam / sponge filter material .
but air must be able to pass thru it - not all sponge materials allow air thru
Probably the least changed filter on cars .
