Shrill Sound Turning The Steering Wheel
6 replies to this topic
#1 PACINO
PACINO
  • 759 posts
Posted 29 May 2025 - 09:35 PM
Hi everyone! For a few weeks now, when turning the steering wheel sideways, I've been hearing a low, "heavy, dry" sound. It seems like there's a lack of lubrication somewhere. 10 months ago, new bushings were installed in the steering column (from the center of the steering wheel to the bottom), and a new steering box was also installed. What can I do to make it run smoothly and stop that sound?
Cheers in avance!
#2 68Deluxe
68Deluxe
  • 34 posts
Posted Yesterday, 03:01 AM
Cheers in avance!
Its not the indicator switch housing rubbing on the steering wheel by chance?
#3 DeadSquare
DeadSquare
  • 3,127 posts
Posted Yesterday, 04:05 PM
To help locate the sound, you could try disconnecting the Steering Column from the "Steering Box" (aka the Steering Rack) and see if turning the Steering Wheel, makes the noise.
#4 PACINO
PACINO
  • 759 posts
Posted Yesterday, 05:45 PM
Thanks friend. Yes, it's a way to rule things out. But isn't there something that can be greased? Perhaps a good squirt of WD-40 down the steering column... because I understand that the steering box (steering rack) being new, doesn't need any maintenance now, or does it?
#5 Tupers
Tupers
  • 4,154 posts
Posted Yesterday, 06:08 PM
What age car do you have?
Pre 1985 Minis had a felt bush at the bottom of the column that should be soaked in oil before fitting.
#6 PACINO
PACINO
  • 759 posts
Posted Yesterday, 09:39 PM
Yes, exactly. This one predates 1985. You've explained it very well. That felt was replaced along with the bushings, and I already told the professional who did the work to soak it in oil. Whether he did it or not, I don't know. I'm going to put some oil on it.Thanks a lot man!
#7 NLinPEN
NLinPEN
  • 83 posts
Posted Today, 01:43 AM
Does the sound happen when you rotate the steering wheel both to the left and to the right? Or only in one direction?
