Centre Speedo Relocated To In Front Of The Driver
8 replies to this topic
#1 Tait
Tait
    Just On Tickover
  • 6 posts
Posted 30 May 2025 - 09:57 AM
Hey guys,
Has anyone moved the centre speedometer to in front of the driver similar to the David brown minis
I’m wondering if there were any issues I’m not considering.
Thanks in advance
Picture attached  :D
#2 stuart bowes
stuart bowes
  • 2,290 posts
Posted 30 May 2025 - 10:33 AM
For pics best to use external hosting like imbb or similar, get the link and copy/ paste here
#3 Steve220
Steve220
  • 5,084 posts
  • Local Club: BMC
Posted 30 May 2025 - 11:01 AM
You may find the speedo cable has to be bent quite sharp to make it work - this will need replacing anyway. Custom brackets may also be needed as the bulkhead contour is different on the sides
#4 Tait
Tait
    Just On Tickover
  • 6 posts
Posted 30 May 2025 - 12:56 PM
Oops, hopefully this works
https://ibb.co/4nLYZzqq
#5 Tait
Tait
    Just On Tickover
  • 6 posts
Posted 30 May 2025 - 01:00 PM
Thanks Steve, those were my thoughts too
Assuming the gauge fits between the bullhead and the dash, I could reroute the speedo cable through a new hole in the right place.
#6 MiniMadRacer
MiniMadRacer
  • 897 posts
Posted 30 May 2025 - 01:30 PM
You probably need a longer speedo cable, similar to the one used in the Clubmans.
#7 mab01uk
mab01uk
  • 12,636 posts
Posted 30 May 2025 - 01:33 PM
Centre Speedo cable is 26" long:-
https://www.minispar...-central-speedo
Minispares do a range of different lengths for Smiths centre speedo, you will probably need a cable length close to the Clubman length but with the earlier threaded fittings each end:-
https://www.minispar...terior/16/1603/
For mounting the speedo in front of the driver maybe you could adapt/modify the RHD Clubman dash mounting bracket assembly, like this (2 clock) one on ebay:-
https://www.ebay.co....ixoC3XoQAvD_BwE
Rear view of Clubman speedo mounting bracket to bulkhead.
Edited by mab01uk, 30 May 2025 - 01:45 PM.
#8 Ethel
  • 26,185 posts
Posted 30 May 2025 - 02:51 PM
A cable for an 1100/1300 could do the job, but it could be easier to get one made unless you can find new old stock.
Would it actually work that well? The steering wheel seems more likely to obscure your view. There are smaller speedos in the same style, but lacking the fuel gauge.
We have a dash directory for perspiration.
#9 mab01uk
mab01uk
  • 12,636 posts
Posted 30 May 2025 - 04:24 PM
SPEEDO CABLE 36" THREADED BOTH ENDS.
Extra long cable for Smiths central located speedo when position moved in dash:-
https://www.minispar...eaded-both-ends
Paul McCartney's Radford Mini dash
Edited by mab01uk, 30 May 2025 - 04:29 PM.
