Emerald Ecu
12 replies to this topic
#1 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 31 May 2025 - 02:39 PM
Have had engine out and lots of other bits since Feb, just got it all back together. I have an Emerald ECU running fuel injected s/c. It’s got a red light on it, and won’t turn the fuel pump on. Is it possible it’s lost its config/map? I’ve had the battery on trickle charge but disconnected from the loom since about feb. I assumed it was some form of ROM it got saved to or other non volatile memory.
#2 Davidmt
Davidmt
  • 219 posts
Posted 31 May 2025 - 04:07 PM
If you do not see the ECU status LED turn from red to green during cranking, please refer to our FAQ section on our website (EmeraldM3D.com - FAQs) for further advice.
Red light needs to change to green when cranking - you have an issue!
#3 Shooter63
Shooter63
  • 1,092 posts
Posted 31 May 2025 - 04:54 PM
I had a car running an Emerald, check your ECU and body earth's, if they are all OK check your timing sensor is set at the correct distance and is working. I am presuming that the power feed is good as you have a red LED.
Shooter
#4 stoneface
stoneface
  • 400 posts
Posted 31 May 2025 - 07:46 PM
I run an emerald k6 and it's been left for 5 years without a battery connected and started today no problem, so it shouldn't have lost the map.
No problem is a bit of a lie as I couldn't get a spark at first but cleaned a few connection on the trigger sensor and it fired up.
#5 stoneface
stoneface
  • 400 posts
Posted 31 May 2025 - 07:48 PM
Also, if you have an inertia cutoff switch on the fuel pump, check its on and working.
#6 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 31 May 2025 - 07:56 PM
Will check that the crank sensor. I always thought the fuel pump kicked in when the ignition was on but it’s been that long I can’t be certain. Replaced all the fuel lines while engine was out, tank was out, MPI type. Was checking for fuel leaks guess I could just power the pump direct from a 12volt source,
#7 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 31 May 2025 - 07:57 PM
There is no inertia, it’s wired from the ECU via a relay. It’s an MPI tank/pump.
#8 stoneface
stoneface
  • 400 posts
Posted 31 May 2025 - 08:24 PM
Thats the problem I have. I built it so long ago that I forget how I wired everything up and then spend many hours trying to figure out the birds nest of wires.
I hate electronics and wiring. It's just coloured string that goes up in smoke when it goes wrong.
Mechanics is so much easier.
#9 Bobbins
Bobbins
  • 1,525 posts
Posted 01 June 2025 - 05:50 AM
How high is the cranking voltage? If it’s too low the Emerald light will remain red during cranking, I can’t recall the exact voltage but I think it needs more than around 11 volts, it’s in the Emerald documentation … which I assume you have?
Have you also checked the immobiliser status?
#10 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 01 June 2025 - 10:49 AM
Hmm, I’ve had the battery on trickle charge for a few months. I’ve not tried to crank it just yet, ordered some more oil as I only had a small drop left over. I was just seeing if there were any fuel leaks since I replaced all the lines and filter. I was convinced the fuel pump started when the ignition was on but come to think of it that would be a bit dangerous potentially! It’s definitely wired from the ECU so will be controlled by it using other variables no doubt.
Its not got an immobiliser, it’s a 1976 but retro fitted with new standard loom but additional loom to support the fuel injection bits and bobs.
#11 stoneface
stoneface
  • 400 posts
Posted 01 June 2025 - 11:30 AM
My fuel pump comes on with the ignition switch before the engine is started.
I suppose it depends how you have it wired.
#12 sonscar
sonscar
  • 3,062 posts
Posted 01 June 2025 - 01:09 PM
Most systems run the fuel pump briefly at key on to prime the system.There should be a relay that the ECU provides the earth to.Just my experience,Steve..
#13 stoneface
stoneface
  • 400 posts
Posted 01 June 2025 - 01:33 PM
Thats exactly what mine does. It primes on first key turn.
