When removing the old brake line under the car, all the rubber protectors that prevented metal-on-metal contact were damaged. What can I use to protect the new brake line during installation?
Brake Line Protection
Lorenzo_H201
, Jun 01 2025 06:10 PM
5 replies to this topic
Posted 01 June 2025 - 06:10 PM
Posted 01 June 2025 - 06:19 PM
Fuel hose can work.
Posted 01 June 2025 - 06:35 PM
Insulating tape.
Posted 01 June 2025 - 07:47 PM
Heat shrink,Steve..
Posted 01 June 2025 - 10:52 PM
I had some 1.5 mm neoprene sheet cut 30mm x 60mm pieces wrapped the 30 mm width round the pipe pushed the pipe into the clips and closed/ bent the clip with my thumb. 6 thousand miles later nothing has moved or come unclipped and no fraying on the pipe as the neoprene holds the pipe away from the body between the clips.
Posted 01 June 2025 - 11:21 PM
Amalgam tape could be good
