Getting pinking on a recently built engine. 1310 A+ / 12g940 lead-free / HIF38-red spring / Kent 246 - which I believe is not much different from an MG Metro cam? The engineer who did the rebore and skim told me he would aim for 10.5:1 (and as a complete noob I said "whatever" - should've said aim for 9.5 or 10 I guess.)
I can drive like a granny, and get no pinking at all. So if the only answer is head off then I can leave the fix until salt-on-the-roads winter-time. Right now just want to get some ideas about what's the best answer, please.
Symptoms are: floor it coming off a roundabout (especially uphill or when towing)... and when the rpms hit 3500 the pinking starts just like a switch has been pressed and continues all the way up the rev range. Ease off slightly and the pinking stops. Floor it again and after a second or so (the delay caused while the carb piston lifts?) the pinking starts again.
What are my options...
Better fuel... doesn't seem to make any difference using E5 or E10.
Change ignition timing... already tried a 2-degree retard and makes no observable difference.
Try to richen the needle at the thin end? (This needle was hand-made on a rolling road so it's not a case of 'just' buying a different needle.)
Have the distributor curve changed or buy a more appropriate distributor?
Or is the only possible answer to have the head off and increase the volumes?
Edited by alpder, 02 June 2025 - 09:26 AM.
