Under Bumper Spotlights
12 replies to this topic
#1 Dominic1998
Dominic1998
    Just On Tickover
  • 5 posts
Posted 09 June 2025 - 08:21 PM
Hi all,
I'm deciding on the styling for my 1986 Mini Chelsea and want to go with a pair of lucas square 8 or another form of square spotlight/foglight to go under the bumper. Does anyone have any photos of this as google is absolutely useless in finding photo examples and also have any advice of how to fit them. Cheers  :proud:
#2 mab01uk
mab01uk
  • 12,563 posts
Posted 09 June 2025 - 10:14 PM
#3 bpirie1000
bpirie1000
  • Area Managers
  • 2,395 posts
  • Local Club: Amoc
Posted 10 June 2025 - 03:27 AM
Back in the day I used two reverse lamps ender the bumper just drilled into the bumper lip and mounted that way.
https://oldskoolmini...s-cooper-rover/
Plenty prewired kits available and how to connect it to main loom on line.
#4 nicklouse
  • 18,719 posts
Posted 10 June 2025 - 08:47 AM
That low they must be fog lamps.
#5 DeadSquare
DeadSquare
  • 3,205 posts
Posted 10 June 2025 - 09:15 AM
Somebody, like 'Les Leston', sold a pair of brackets that bolted to the Subframe, using the nut of the suspension Tie Bar.
#6 Bobbins
Bobbins
  • 1,524 posts
Posted 10 June 2025 - 03:06 PM
As Nick refers to, under bumper was always fog lamps, low down is good for short distance illumination such as the sides of the road but no good for penetrating any sort of distance. These were usually rectangular to enable decent size fog lamps to be fitted with less fear of them catching something.  Higher up is much better for distance, i.e. spot lamps or 'driving lamps'.
#7 Cooperman
  • 23,332 posts
Posted 13 June 2025 - 09:18 PM
Legally under-bumpers lights are for use in foggy conditions only. I can’t remember the actual definition of fog, but I think it’s visibility of 100 yards or less.
From memory, in order to use auxiliary lights for normal driving, the centre of the light must be 16” above ground level. Then those lights must automatically go off when dipped beam is selected.
Low set fog lights may be used with the headlights switched off to reduce glare in thick fog. They must be mounted as a pair.
#8 Ethel
  • 26,098 posts
Posted 13 June 2025 - 09:29 PM
Certainly 100m for rear fogs. Front fogs are likely a bit more complicated as you can use them without headlights - provided they are fitted in the correct place. I don't think it would be a good idea with them that low though, you could easily disappear in even a small undulation in the road.
#9 Dominic1998
Dominic1998
    Just On Tickover
  • 5 posts
Posted 22 June 2025 - 04:21 PM
Thanks for the advice all, I've fitted some under bumper driving lights and whilst they might not be useful in that spot I've just done it for a bit of fun and for aesthetic reasons. Proper lovely  :D
Attached File  DOROTHY.jpg   100.11K   3 downloads
#10 Ethel
  • 26,098 posts
Posted 23 June 2025 - 08:10 AM
They look alright.
They won't be useless. You might find they create shadows on undulating road surfaces.
#11 SKIDDERWOLF
SKIDDERWOLF
  • 319 posts
Posted 24 June 2025 - 02:26 PM
Really like the indicator and I guess sidelights on this mini
#12 mab01uk
mab01uk
  • 12,563 posts
Posted 24 June 2025 - 07:04 PM
They are Austin/Morris 1100/1300 (ADO16) indicator/sidelights and were a common upgrade for 'Coachbuilt' Radford or Wood & Pickett Minis back in the 1970's. Also breakers yards were full of rusty 1100/1300's for Mini owners to get them cheaply secondhand!
Usually some on Ebay:-
https://www.ebay.co....0xoCZY8QAvD_BwE
Edited by mab01uk, 24 June 2025 - 07:06 PM.
#13 SKIDDERWOLF
SKIDDERWOLF
  • 319 posts
Posted 24 June 2025 - 07:33 PM
Thanks for the reply mab, this has now got me thinking…….
