at the same time (like the same hour) that I discovered the vacuum leaks in my carb, the engine was making a knocking sound when I hit the gas. Got it all back together and the knock persists. I looked under the valve cover and found there were little pieces of wire that were wound up like springs. I found (3) 1 inch or so sized pieces, and was able to retrieve two of them. The car is running somewhat reasonably despite the noise.
I didn't open up the engine below the head (except to replace tappet cover gaskets and a new fuel pump) when I had it off the road for so long, so I don't recognize what the might be or where they came from.
Does anybody know what this is?I'm already assuming it's something horrible.
