1995 Mini Sprite Spi - Can Anyone Help Me Identify These Loose Wires Behind The Clocks?
5 replies to this topic
#1 BarryCraig
BarryCraig
    Starting My Mini Up
  • 2 posts
Posted 11 June 2025 - 03:08 PM
Hi All,
I'm pulling my hair out with these 3 loose wires. They come out of the loom behind the dials of my 1995 mini Sprite.
Single wire, green with orange stripe ending in a square terminal
Single wire, white with a black stripe ending in a spherical terminal
Two wires, purple with an orange stripe and yellow with a purple stripe
If anyone can point me in the right direction with any of these I would be hugely grateful. I inherited this mini and have been trying to put it back together and thes three have me totally stumped.
Many thanks!
#2 NLinPEN
NLinPEN
  • 93 posts
Posted 12 June 2025 - 02:16 AM
1. I believe that it is light green & orange (Mini uses light green and dark green wires). In the schematic diagrams that I have I found only one wire with that color combination. It is the wire that goes from the 15 Amp fuse (location in fuse box: A8) to the blower assembly.
2, The engine management system is using some black&white wires. One of those go to a module called "instrument pack", but I'm not sure what they mean by that. This "instrument pack" has two wires: a white&black one, and a green&blue one. Maybe you can locate it by the color of this second wire?
3. I'm not sure what this third pair of wires is. Purple&orange indicates that it is a wire from a fuse to an accessory (e.g. radio, clock, etc). But I can't find the yellow&purple wire in the schematics I have.
#3 nicklouse
  • 18,653 posts
Posted 12 June 2025 - 09:10 AM
Looked in here for your harness.
https://www.theminif...agrams-redrawn/
#4 BarryCraig
BarryCraig
    Starting My Mini Up
  • 2 posts
Posted 12 June 2025 - 09:24 AM
Thank you very much! That is immensely helpful.
#5 humph
humph
    How bad can it Be?
  • 1,103 posts
Posted 12 June 2025 - 01:41 PM
Full wiring diagrams here;
From memory on mine, check the diagrams.
Single wire, green with orange stripe ending in a square terminal - Tachometer but could be "WASH WIPE, HEATER, INSTRUMENT, AUXILIARY COOLING FAN AUTOMATIC GEARBOX SELECTOR ILLUMINATION"
Single wire, white with a black stripe ending in a spherical terminal - Tachometer
Two wires, purple with an orange stripe and yellow with a purple stripe - This is the little flashing LED for the alarm
#6 viz139
viz139
  • 675 posts
  • Local Club: Irish Mini Owners Club
Posted Yesterday, 10:39 PM
Green/ orange is a feed to tacho
white/black is tacho pulse.
I don't think the Sprite came with a tacho so they are not connected to anything.
purple/orange is the feed to stereo
yellow/purple is from ECU to Throttle potentiometer so  not at instruments .
Some speaker wires are yellow so cheak that tracer colour
