I've had the engine out for a while doing various bits. I also installed a "new old stock" gearchange housing with new bushes and rubber mounts. Had a new change rod made up since they are NLA. All fitted back ok, the gearchange feels very tight, I put this down to the new parts plus I also installed a KAD quick change, new.
One thing I did notice, after connecting it all up underneath I forgot to install the reverse switch, so I undone the two rod house rubber mounts from within the car and dropped the unit to make it a bit easier to get the switch in. When I went to put it back, the holes in the body for the mounts were out by about 1/4 inch! I had to undo the nut that holds the steady bar to the gearbox to allow the housing to move back far enough for the mounts to line up with the holes in the body, then do up the nut.
Would this be causing any unwanted stiffness in the gear change?
Might be just I've not driven it in ages and fitted a short shift lever plus installed new parts with all new bushings etc.
Ta.
