1275 A+ Mods For Track Days
3 replies to this topic
#1 rick1962uk
rick1962uk
  • 54 posts
Posted 14 June 2025 - 06:44 PM
hi all welding done and will be painted soon so im going to start rebinding the engine its a metro 1275 A+ lump single carb
now power at the moment is not to important but for fast road / track days is there any important parts i need to change
it will have a pre verto clutch and electric fuel pump just want to get the bottom end right first time
also do these need a sump baffle or do they cope
many thanks
#2 DeadSquare
DeadSquare
  • 3,205 posts
Posted 14 June 2025 - 07:59 PM
Bottom end:-  A modified oil pick-up that is nearer the centre of the box is a useful mod,  Some people used to plug the holes in the centre web, but I never saw the point as oil can flow through the diff,
Have the crank / flywheel,rods and pistons balanced and an 1" square strap over the shaved centre main bearing cap.
Top end:-  fit a supercharger..
#3 rick1962uk
rick1962uk
  • 54 posts
Posted 15 June 2025 - 04:00 PM
many thanks thats a great starting point
#4 Cooperman
  • 23,332 posts
Posted 29 June 2025 - 07:09 PM
I would suggest, in addition to the centre main bearing cap strap, full balance of all rotating parts and a centre oil pick up that you consider the following:
Lightweight steel flywheel
A really well has-flowed big-valve head
A better cam to suit your application. Something like an SW5, Kent 276 or similar ( look at the cam graphs below deciding).
LCB exhaust manifold
Twin HS4 carbs
A matched distributor
Quality high comp pistons (MS Evo pistons are excellent)
A higher comp ratio.
Then you need to consider the final drive ratio. This is a personal choice, but suffice to say that it is a balance between acceleration and cruising speed. Maybe a 3.44:1 would be about right if you are keeping standard gear ratios. This gives around 16.5 mph/ 1000 rpm in top gear and great acceleration.
For overall performance the suspension is as important as the power and torque. But that’s another subject.
Also you might consider a Cross Pin Diff for reliability.
