Well I Didn't Know That
9 replies to this topic
#1 Shooter63
Shooter63
  • 1,061 posts
Posted 14 June 2025 - 10:04 PM
I went to see one of my mates today, apart from being a demon painter he's also an electronics buff, he has a side line in repairing knackered MIG welders. He told and showed me something I have never seen written or mentioned before. He started a car with a dead battery using a MIG welder!!!
He disconnected the wire feed, took the shroud off the torch, hooked the lead up, touched the torch onto the battery terminal, he pulled the trigger, I hit the key, and bugger me it started.
Shooter
#2 Avtovaz
Avtovaz
  • 1,262 posts
Posted 14 June 2025 - 10:45 PM
i have wondered about this before lol ! id imagine it would be easy to spike the electrics unless you know what you are doing.
#3 Spider
  • 15,015 posts
Posted Yesterday, 06:19 AM
They are basically a DC Power Pack. a TIG will do the same.
While it will work, I wouldn't make a habit of it !
#4 absx2
absx2
  • 918 posts
Posted Yesterday, 06:34 AM
I wouldn`t do it on anything with an ECU or retro fitted electronic ignition.
#5 nicklouse
  • 18,652 posts
Posted Yesterday, 08:11 AM
Likewise you can use a battery as a stick welder.
#6 68+86auto
68+86auto
  • 962 posts
  • Local Club: Queensland Mini Car Club
Posted Yesterday, 08:43 AM
Some mig welders (Kemppi) actually had a setting to use them as a jump starter and battery charger.
The issue with using welders not designed for this is that most have a voltage far too high. Not so much of an issue now with inverter welders as they have more adjustment.
Edited by 68+86auto, Yesterday, 08:44 AM.
#7 Spider
  • 15,015 posts
Posted Yesterday, 10:35 AM
Like this ?
#8 nicklouse
  • 18,652 posts
Posted Yesterday, 10:56 AM
Like this ?
Oh I knew there were some old chaps who had to do this in the backend of Nowhere. ;)
#9 DeadSquare
DeadSquare
  • 3,151 posts
Posted Yesterday, 11:45 AM
Shooter
Did the ignition and oil lights still work ?
#10 Shooter63
Shooter63
  • 1,061 posts
Posted Yesterday, 03:42 PM
Shooter
The car was a 14 plate fiesta, everything worked as normal, as he said " know what you doing, know your welder"
Shooter
