Exhaust Rear Hanger Mount Missing?
4 replies to this topic
#1 StudioTwo
StudioTwo
  • 13 posts
Posted 15 June 2025 - 05:55 PM
Hi all,
I have a 1990 Studio 2 and one of the items on the health check was the exhaust rear mount and bracket was missing. I've looked across the web but cannot find a picture of how it should look so unsure what parts to get!? I figured it's a job I can do....if I had the right parts.
Underneath there is a bracket arm with an old bit of possibly a rubber part (underlined in green in the picture) and there is also a hole (circled yellow) in the subframe so I assume that had a mount bolted on it?
Anyway, if I could visually see how a bracket is meant to be mounted and the parts associated with it, I'd be good to go! Thanks in advance for the help (and links to MiniSpares if poss!).
Cheers all!
Attached File  IMG_3203.jpg   50.6K   1 downloads
Edited by StudioTwo, 15 June 2025 - 05:57 PM.
#2 Chris1275gt
Chris1275gt
  • 969 posts
Posted 15 June 2025 - 07:25 PM
Don’t know if this will help
https://www.somerfor...tandard-1985-on
#3 StudioTwo
StudioTwo
  • 13 posts
Posted 15 June 2025 - 07:39 PM
Thanks! Certainly gives me a bit more perspective. I will probably bite the bullet with the clip tail pipe mount and the cotton reel. Just wanted to see how it all looks when fitted to the subframe but so long as it holds the exhaust, we should be good.
#4 mini-mad-mark
mini-mad-mark
  • 883 posts
  • Local Club: northants wot no brakes
Posted 15 June 2025 - 07:40 PM
Looks like you need:
https://www.minispar...-for-gex177-etc
and
https://www.minispar...l-exhaust-mount
The "cotton reel" mount is the bit on your subframe you've highlighted  (broken in your case)
Looks like you may have had a replacement subframe at some point with the later hanger type
#5 StudioTwo
StudioTwo
  • 13 posts
Posted 15 June 2025 - 07:49 PM
and
Understood, thanks! That makes sense. It does look like it was converted (the groove out of the subframe suggests that too perhaps) and then restored. Anyway, I'll get those bits I think and give it a go! Thanks. :)
