Any Builders On Here?
Posted Yesterday, 02:00 PM
We are thinking of getting an aquarium which will be 180 litres. This will sit on top of the substantial sideboard we already have.
So, with the weight of the water, tank, sideboard and contents I've guesstimated around 250kg all in.
This is going up against a wall on a newly built floor which is chipboard across joists which from memory are either 8"X2" or 10"X2"
Will the floor take this weight?
Posted Yesterday, 03:01 PM
Is the sideboard on feet?
Posted Yesterday, 03:18 PM
Ahh, I see where your going with this. I'd never thought of the localised stress on the feet.
Edited by Gaz66, Yesterday, 03:22 PM.
Posted Yesterday, 03:22 PM
If the joist are at right angle to the wall, and let into the wall, not on hangers, that weight against the wall should be ok
Edited by DeadSquare, Yesterday, 03:25 PM.
Posted Yesterday, 03:25 PM
If the joist are let into the wall, not on hangers, that weight against the wall should be ok
Yes, they are in the wall.
Posted Yesterday, 03:27 PM
Im not a builder but the thought occurs to me to line up the legs with the joists instead of between the joists. you may already be assuming that but it's not been said
Posted Yesterday, 03:54 PM
I would try and do that but.....Im not a builder but the thought occurs to me to line up the legs with the joists instead of between the joists. you may already be assuming that but it's not been said
Over the chipboard is 6mm ply and lvt flooring so can't actually see where the joists are anymore.
Posted Yesterday, 04:29 PM
ah I see, I thought it was just the chipboard which isn't that great for strength, that's all, but with the ply and other layer as well you may well be fine
Posted Yesterday, 05:25 PM
Posted Yesterday, 06:08 PM
you could triangulate backwards, from the outer edge of the self down to the wall near floor level, that would take strain off the front legs
if it even needs it, I'm not saying it does necessarily
Posted Yesterday, 06:25 PM
Shooter
Posted Yesterday, 06:40 PM
Google says that's about a bathful, not aware of bathrooms having more substantial floors. Alternatively 3 ten stone bods sat on a settee would create a higher load.
Posted Yesterday, 08:04 PM
BuildHub (linked below) is a really good friendly forum for any DIY Building related questions, research, etc.
https://forum.buildhub.org.uk/
Posted Yesterday, 08:23 PM
Yes, four of them but I was thinking of adding two more in the middle.
If the feet are in the middle of the gap between joists, and it's good quality 22mm chipboard, you should be OK.
Unless the chipboard gets damp but, underneath an aquarium, what are the chances of that happening?
Posted Yesterday, 09:44 PM
Shooter
