Crank Pulley Mark
9 replies to this topic
#1 gaspen
gaspen
  • 970 posts
Posted 20 June 2025 - 07:47 AM
Hello
I have this timing cover and pulley for my 850. There is no timing mark on any of them but I would like to file one on the pulley and spot weld a scale on the cover.
I found a drawing on an MG forum for the position of the pulley mark.
Is it the same on the Mini ?
Attached File  20250620_093346.jpg   75.21K   0 downloads
Attached File  BH_T-marks.JPG   36.62K   0 downloads
#2 DeadSquare
DeadSquare
  • 3,172 posts
Posted 20 June 2025 - 08:51 AM
Are the timing marks on the flywheel no longer visible ?
#3 gaspen
gaspen
  • 970 posts
Posted 20 June 2025 - 08:54 AM
Yes they are visible but they hard to see after I will install the engine
Now the engine is on a stand, the crank is in TDC at #1.
#4 nicklouse
  • 18,679 posts
Posted 20 June 2025 - 08:55 AM
I would forget about trying to reproduce the OE set up.
i would also invest in a timing light with adjustable dial on it.
make/buy a pointer and then mark up TDC to suit.
have a look at https://www.q1classi...5-based-engines
#5 imack
imack
  • 2,195 posts
Posted 20 June 2025 - 11:52 AM
I made my own pointer, then set the engine to true tdc using the dial gauge and timing disc method, then filed a notch in the crank pulley to align with the pointer at tdc.
You will need to use a dial back timing light though.
Edited by imack, 20 June 2025 - 11:53 AM.
#6 Chris1275gt
Chris1275gt
  • 964 posts
Posted 20 June 2025 - 01:34 PM
I made this little contraption which after removing the cover from the wok then use the bolts to attach it to the housing and it’s easily viewed from above with a timing light. Patent pending!!
Edited by Chris1275gt, 20 June 2025 - 01:35 PM.
#7 68+86auto
68+86auto
  • 989 posts
  • Local Club: Queensland Mini Car Club
Posted 20 June 2025 - 01:43 PM
The MG ones are in the wrong position. They are seen by looking under the car.
Simply put the engine at TDC according to the flywheel and make a mark wherever you want. There is no need for a scale when using a dial back timing light.
Edited by 68+86auto, 20 June 2025 - 01:44 PM.
#8 imack
imack
  • 2,195 posts
Posted 20 June 2025 - 02:11 PM
Sorry, here's the factory one from the early 1960's!
Edited by imack, 20 June 2025 - 02:12 PM.
#9 DeadSquare
DeadSquare
  • 3,172 posts
Posted 20 June 2025 - 03:31 PM
At the NEC sports car show, a few years back, a chap was selling those with an AAA cell behind the mirror and a diode to light the flywheel.
#10 gaspen
gaspen
  • 970 posts
Posted 24 June 2025 - 08:38 AM
Thanks for your advices
Finally I found a bad cover from which I removed the timing mark and spot welded to my cover
(The pulley isn't fixed yet)
Attached File  20250623_174752.jpg   28.97K   0 downloads
