Engine has been rebuilt recently including new alternator, and is running genrally fine , though timing has wandered a few degrees judging by spark plugs in first 1000 mile of running in.
But when I start her up , it sounds like the battery is flat on the first full turns - slow crank and now attempting to fire. Then by 3rd or 4th pull , the engine fires up fine.
Starts easily when warm no problem. But also noticed my smiths voltmeter shows no voltage when engine is cold , until the engine starts. If I start it from warm the voltmeter reads something between 0 and 15 v depending on how long it has been left as far as I can tell.
Anyone got `nu ideas in starting problem ? Solenoid ?
Should the voltmeter show battery voltage as soon as ignition is switched on ?
Its a 998cc 1989 with lucas sports coil and power spark electronic ignition
