Call me crazy but in this house life's for livin'
Posted Today, 04:06 PM
Posted Today, 04:18 PM
Posted Today, 05:14 PM
Intermittent grinding noise from the engine bay, turned out the alternator adjusting bracket had broken off from the end plate and was swinging back and forth ocassionally hitting the alternator belt. Took ages to work out what had happened, once I found the issue I was able to get home with the bracket removed and sort it out...
Posted Today, 05:22 PM
Good luck with trip, I'm sure you have an array of spares for the ignition system, elecs etc.
Assuming you have an electric SU fuel pump like mine, you may, like me not trust it one bit; so I carry a spare Facet fuel pump and to save scrabbling under the car to fix/replace if/when it fails. With a short rubber pipe attached to the Facet pump it can be easily patched in series into the fuel line by the carburettor and then with a nearby 12v to power the pump, fuel will pass straight through the dead SU pump from the tank straight through to feed the carbs and away you go.
Another 'experience', I had was on a trip home to Birmingham from the London to Brighton Mini Run (a great event sadly now cancelled) was my clutch master cylinder packed up, no cluch stuck in stop start traffic on the M25 was not fun, in gear starts from standstill and clutchless gear changes. I stoped at nearly every service station to bleed the cluch which would give me a few presses to help limp home. So check out your cluch hydraulics. Lastly consider an electric fan to supplement the belt driven fan. All the best Steve.
Posted Today, 05:47 PM
Posted Today, 05:55 PM
Ah very good idea - mine is actually a mechanical pump currently but nothing silly about having a spare... Do you have it plumbed in, or just to hand to swap?
Still sore that I never got to do an L2B run!
I just carry as a spare also some small jubillee clips ;)
Posted Today, 06:31 PM
Sound a fantastic trip ! I'll add to the road side stories a little later.
As long as the fuel pump, be it electric or mechanical isn't leaking or blocked, you can leave it in place, plumbed up and fit a temporary pump under the bonnet. It will draw through the normal pump OK.
Posted Today, 06:55 PM
My best one ...
clutch slave went in the middle of the middle of no where ,
screen-wash pipe into the top of the clutch master cyl reservoir ,
pump like mad till i had a pedal to pull away ,
all the other gears I could change without clutch (except reverse)
and water pump leaking out tell tale hole , managed to ram a bit of rag in there
screen wash into rad cap hole - got me home ,
and old jump lead to tie exhaust back on .
also drove a mini back to garage on a beer crate , after customs stripped it at dover .
fun days
also our work pickup went in a puddle & knocked off dizzi cap in pitch black ,
in middle of flooded road single track ,
took int mirror off & used reflected light to get cap back on , jammed it on with rag
never found little clip that held it on .
Edited by sledgehammer, Today, 07:01 PM.
Posted Today, 07:18 PM
My best one ...
