Something Fell Off
4 replies to this topic
#1 SKIDDERWOLF
SKIDDERWOLF
  • 315 posts
Posted 23 June 2025 - 06:05 PM
Whilst driving along today in my Mini something fell off (from a brief glimpse looked to be an exhaust clamp) under the car and proceeded to bounce into the ditch behind me. I obviously stopped pretty sharpish walked back up the road but could not find what had fallen off, had a visual check under the bonnet and under the car- exhaust clamp was my first thought however all were present. Fortunately I was not far from home took it slow and the car seemed to behave perfectly fine, no unusual knocks or vibrations or sounds. Fortunately nobody was following when this happened and I will give the car a through check over before using the car again however I am currently clueless as to what it was. Is there anything prone to falling off that I should check???
#2 Spider
  • 15,076 posts
Posted 23 June 2025 - 06:15 PM
It would have been you most expensive and treasured Socket Ratchet.
#3 SKIDDERWOLF
SKIDDERWOLF
  • 315 posts
Posted 23 June 2025 - 06:17 PM
I’ve done an inventory check on return to the garage, all tools seen to be there. It’s always a worry though - that spanner which falls between the subframe and bulkhead!!
#4 Quinlan minor
Quinlan minor
  • 1,206 posts
  • Local Club: LSMOC
Posted 23 June 2025 - 06:18 PM
Bear in mind that it may have fallen off some other vehicle and been flicked up by a tyre as you passed over it.
Obviously, you should thoroughly check your Mini but, if you don't find anything missing, this might be the explanation for what you heard and saw.
#5 sledgehammer
sledgehammer
  • 3,107 posts
Posted 23 June 2025 - 06:45 PM
Another 10mm released into the wild .
    Google (1)
