Engine Removal
Posted 25 June 2025 - 04:00 PM
Posted 25 June 2025 - 04:09 PM
have you removed lower arm bump stop rubber? should be able to get bar under damper mount on top bar and lever up slightly. I usually split pot joints then pull them out as engine is raised do one side then the other by jiggling engine about. old crane was fixed so had to move car and came up with this so stuck with it for years
Edited by coopertaz, 25 June 2025 - 04:10 PM.
Posted 25 June 2025 - 05:14 PM
Shooter
Posted 25 June 2025 - 06:30 PM
Posted 25 June 2025 - 06:58 PM
Posted 26 June 2025 - 06:58 AM
Posted 26 June 2025 - 07:03 AM
Like imack said, get all of the lower stuff out of the way, that's your best bet. Maybe even disconnect the steering arm. Without fully compressing the rubber donut, there is no way that the upper arm is going to move.
Posted 26 June 2025 - 07:05 AM
What about CAREFULLY, jack up the car on the upper control arm. It will compress as the weight of the car is transferred to the top arm.
Posted 26 June 2025 - 07:24 AM
Posted 26 June 2025 - 08:52 AM
I use a ratchet strap from top shock mount, around top arm and back to shock mount. Then tighten. That'll raise the top arm enough to push down and pull the ball joint out of the way.
Posted 26 June 2025 - 03:38 PM
Posted 26 June 2025 - 04:58 PM
Sorted thanks one and all
Which of these if any did you end up utilising for your repair?
