Easier Method To Remove Sills?
Posted 27 June 2025 - 09:57 AM
Posted 27 June 2025 - 10:03 AM
Posted 27 June 2025 - 10:28 AM
power file / finger sander was my weapon of choice, I found it easier to be accurate and get just through the waste metal without going into the stuff I'm keeping
takes ages though if you're being precise
Edited by stuart bowes, 27 June 2025 - 10:29 AM.
Posted 27 June 2025 - 11:09 PM
Posted Yesterday, 12:43 PM
I did wonder if you meant after drilling with a spot drill. I'd see the remaining spot has an opportunity to make an alignment aid, if you didn't drill on the "keeper" side. As far as chewing off rusty remnants goes, I've found using a set of pliers or mole-grips like a sardine tin key along the panel join is quite effective.
Posted Yesterday, 01:22 PM
10mm belt sander and roloc sander.
Using the belt sander totally replaces spot weld drill bits. I don't use the drill bits unless I need to save both panels.
Posted Yesterday, 03:45 PM
Personally i use 1/4" cobalt drill bits and a very thin splitting blade, BUT if its just a sill then for speed i cut the majority away with a 1mm slitting disc then play hunt the spot weld with a grinder as invariably if things are very crusty trying to find a spot weld can be problamatic even more so if the sill have been previously replaced.
However i have spot weld drill bits with varying success but ill stick to my own mehtod of using 1/4'' drill bit and splitting blade.
BUT this also depends on the equipment and facilities you have to hand. Something to bear in mid for novice mini owners.
Posted Yesterday, 07:38 PM
Same here sometimes, it's like removing wallpaper, sometimes you get a good bit that goes a long way and just peels nicely. Other times (often) you're picking at tiny bits and that's when the power file came out
