Hif44 Turbo Carb Help
8 replies to this topic
#1 robd1996
robd1996
    Just On Tickover
  • 5 posts
Posted 01 July 2025 - 05:37 PM
Hi all,
I’m having issues with fuel leaking from the choke spindle only when engine is running. Any ideas what is causing this?
I have correct fuel pressure with engine not running, have double checked fuel bowl height and seem to be stuck!
Running a 1330 with a blow through set up help appreciated! cheers rob
Edited by robd1996, 05 July 2025 - 07:03 AM.
#2 timmy850
timmy850
  • 3,424 posts
  • Local Club: MITG
Posted 02 July 2025 - 09:32 PM
Have you replaced the rubber seals in the choke mechanism?
#3 Ethel
  • 26,185 posts
Posted 02 July 2025 - 10:38 PM
There's nothing special about the choke on a turbo carb, as far as I'm aware. As Timmy said, the O rings are prone to failure & the difference with a turbo is the pressure can make them leak out as well as suck in.
#4 robd1996
robd1996
    Just On Tickover
  • 5 posts
Posted 04 July 2025 - 11:16 PM
Yes replaced them when I rebuilt the carb, no leaks when not under pressure from the supercharger. I’m thinking there’s too much boost for the carburettor to handle?
#5 timmy850
timmy850
  • 3,424 posts
  • Local Club: MITG
Posted 04 July 2025 - 11:32 PM
If it’s running on a suck through supercharger, then the carb doesn’t see any boost
#6 robd1996
robd1996
    Just On Tickover
  • 5 posts
Posted 05 July 2025 - 07:03 AM
Sorry my bad blow through setup 😂
#7 Ethel
  • 26,185 posts
Posted 05 July 2025 - 07:31 AM
If it's leaking externally fuel must be getting round or through 39
#8 robd1996
robd1996
    Just On Tickover
  • 5 posts
Posted 05 July 2025 - 10:50 AM
I replaced the spindle when I rebuilt with the correct o rings rubber seals turned round etc, do you think the boost pressure from the supercharger is too much for the carb to handle hence the leaking?
#9 timmy850
timmy850
  • 3,424 posts
  • Local Club: MITG
Posted 05 July 2025 - 10:58 AM
If it’s been assembled properly it should be fine with the boost of a supercharger. Turbo minis have stuffed way more boost through a HIF44 than a supercharger could manage
