Leaking Time Chain Cover - Again And Again
Best Answer postve , 06 July 2025 - 06:59 PM
Use rtv
Buying some today as I am gonna be stubborn and not take that damn thing off again!!!!! Go to the full post
13 replies to this topic
#1 postve
postve
  • 588 posts
Posted 06 July 2025 - 02:40 PM
Guys/gals
I will be damned if I have to take this thing off for the 4th time!!!!! I have a brand new timing cover, and the thing still leaks - yes u will see gasket sealer as I am sick of taking this thing off - any other suggestions as tired of this problem - lol
https://imgur.com/a/y3CmHOs
#2 Homersimpson
Homersimpson
  • 840 posts
Posted 06 July 2025 - 03:43 PM
Guys/gals
If it still leaks after using gasket sealer then the leak may not be from there but either the back plate to engine gasket or the seal around the crank pulley.
I would pull the whole lot off, new gaskets, sealant and change the seal again.  Make sure when fitting the timing cover that you put the pulley on while the cover is loose to centralise it on the seal as well.
#3 postve
postve
  • 588 posts
Posted 06 July 2025 - 03:58 PM
I hear ya Homer and been there, new aluminum (fancy red one) backplate, seals and timing cover and the damn thing still leaks -arghhhhh
#4 sca
sca
  • 26 posts
Posted 06 July 2025 - 05:37 PM
Use rtv
#5 Spider
  • 15,253 posts
Posted 06 July 2025 - 05:48 PM
A few things here.
The point on the cover represents one of the low points where oil will run to, from a higher point, so carefully check that it is in fact the timing cover, I've seen head gaskets leak, but down here is where it is easiest seen. Check that it's not the halfmoon seal or the front engine plate gasket.
The cover needs to be centralised before tightening up. There was a tool available for doing this I made mine;-
There's suggestions of using the pulley to do this and that maybe possible, but you need to be 100% sure when inserting each screw that you and not pulling the cover out of alignment, much harder said than done.
Be sure all the threads in the backing plate are flush and not pulled, even a light countershinking here doesn't hurt, but keep it very light as the plate is thin.
Be 100% sure the flange on the cover is dead flat.
Don't over-tighten the cover.
I have had some duff gaskets, it seems they were not made from gasket material !!
The seals in these are usually a double lip type, while nothing to do with sealing them, put some grease between these lips. Be sure the shank of the Damper or Pulley is not grooved.
For what ever it's worth, I use Threebond sealant on these, though prior to going to that, I also had good success with Permatex No. 3.
#6 postve
postve
  • 588 posts
Posted 06 July 2025 - 06:29 PM
Thx Spider and some past pictures putting it in and followed online instructions to the letter - it leaks right at the “valley”, or bottom curve just above gearbox
https://imgur.com/a/QSpb1do
Edited by postve, 06 July 2025 - 06:31 PM.
#7 postve
postve
  • 588 posts
Posted 06 July 2025 - 06:59 PM   Best Answer
Use rtv
#8 Spider
  • 15,253 posts
Posted 06 July 2025 - 07:23 PM
It appears that you replaced the Main Gallery Oil Plugs - good move, however have you checked you're not getting a leak from that ?
#9 postve
postve
  • 588 posts
Posted 06 July 2025 - 07:37 PM
Spider, I don’t think so but I suspect the timing plate might be slightly warped, hence the leak at the bottom
#10 Spider
  • 15,253 posts
Posted 06 July 2025 - 08:05 PM
Assume nothing - check everything !
#11 postve
postve
  • 588 posts
Posted 06 July 2025 - 08:24 PM
Wise advise Spider but I am quite confident that it is a slight warp in the plate (I am angry with myself as I might have over tightened) - gonna go RTV as again I do not want to go through the pain of taking this off again - if that fails - I have no choice - besides it’s 40c over here !!!!
#12 Earwax
Earwax
  • 520 posts
Posted 06 July 2025 - 08:54 PM
A bad pun to keep your spirits up.  Stay postve.     Now in all seriousness, Spider's and Homers thoughts are spot on .
A couple of helpers for the above.
My eyes cant see, but if the oil galley plug has been changed to a grub screw , then thread types can differ slightly. (ask me how i know). I ended up grinding out a little half moon extra off the engine plate so i could access the plug/grub screw in situ.  I used a hydraulic sealant rather than loctite.
the branding on the plate, reminded me of a recent other thread where a Supercharger kit from the same company required elongating of a hole to allow fitment. If you have your old plate , just check alignment- as it is very possible to slightly pull the seal off centre - after centring it.  So check for this as well as straightness - whilst at it check the tensioner bolts fitment ( if you have a tensioner) - for the same thing
Not sure if applies to your engine plate - but the placement of short bolts ( top rear i think) is important to ensure you don't push the timing cover out when tightening.
#13 postve
postve
  • 588 posts
Posted 06 July 2025 - 08:56 PM
Thx as always earwax!!! I am going to do a few prayers for my quick fix but my fate awaits me I suspect!!
Edited by postve, 06 July 2025 - 08:56 PM.
#14 postve
postve
  • 588 posts
Posted 08 July 2025 - 06:04 PM
Okay, winner is RTV - at least for the summer thx SCA!!!!!
