Fuel Tank Repair
27 replies to this topic
#1 gaspen
gaspen
  • 1,003 posts
Posted 11 July 2025 - 06:17 AM
Please be careful before you cut or weld a fuel tank ! It could be dangerous due to fuel or its gases remaining inside the tank.
Hi
I cut the tank in two to clean as a thick "material" sticked hardly on the bottom. Now it's cleaned as good as possible
I have degreaser and Brunox. My idea to brush it with Brunox, weld it, and fill the welding seam with Brunox again.
Finally I'd fll it with POR-15 but I am not sure if Brunox is a good primer fro POR-15
Any advice ?
Attached File  20250709_145616 (1).jpg   93.15K   2 downloads
Attached File  20250709_161338.jpg   54.11K   1 downloads
Edited by gaspen, 01 August 2025 - 05:18 PM.
#2 sonscar
sonscar
  • 3,084 posts
Posted 11 July 2025 - 07:46 AM
Just my experience here POR paint over rust.I bought all there recommended steps and followed the instructions.Months later it peeled off in strips.Use two pack epoxy onto the bare metal.Others may have had better results.rough the surface with 80 grit,NOT a wire wheel.Steve..
#3 mbolt998
mbolt998
  • 411 posts
Posted 11 July 2025 - 07:50 AM
Nice job. I suspect that anything you put in there will melt, smoke, catch fire, and make horrible fumes and a mess when you weld it. Could you weld it first, block up the hole at the bottom, fill it up with something, and then drain it back out of the bottom? That way it would coat everything in there if it was sticky enough. But I don't know what you can put in there anyway that petrol won't wash off.
#4 Spider
  • 15,250 posts
Posted 11 July 2025 - 08:09 AM
POR15 likes lightly rusty or course blasted steels, no primer or anything else there.
For this job though, and again, similar preparation of the steel, they have a Fuel Tank Repair Kit, which would be much better suited. Clean the tank back to bare metal, weld it up, then use their kit which comes with a cleaner and pre-treatment. I suggest welding (or brazing) the tank back together as bare metal as i) it will weld (or braze) better and happier with clean metal and ii) you chosen tank liner will work MUCH better if there's no contamination from burn Brunox or anything else.
For what ever it's worth, I make a few special fuel tanks, which I line with either the POR15 Fuel Tank Kit or we have a local product, KBS, which is just as good.
#5 stuart bowes
stuart bowes
  • 2,289 posts
Posted 11 July 2025 - 08:54 AM
so what do you do once it's welded back in one piece, pour in the POR and just turn it round and round to cover all the surfaces, pour out excess ? or is there some clever trick (just out of curiosity really)
also would it not have been better to pull the seam apart and re-weld that again, instead of now having to seam-weld all round the outside (again just curious if there's some reason) when they make it originally is that just spot welded and how do they get a good seal or is it a roller seam weld thing
Edited by stuart bowes, 11 July 2025 - 08:59 AM.
#6 Ethel
  • 26,179 posts
Posted 11 July 2025 - 10:30 AM
Getting the seam apart would be hard work, but cutting just inside it should leave you with something that's easier to weld up and even easier to braze. I'd have been tempted to chuck some gravel in & tumble it, but have to admit the Gaspen's done an excellent job of cleaning it up that I doubt would have been matched.
#7 gaspen
gaspen
  • 1,003 posts
Posted 11 July 2025 - 11:12 AM
Originally it was welded with a "roller-welder", that's why it does not leak. I haven't got the equipment to cut and re-weld that seam.
POR-15 kit has a degreaser and a surface conditioner, I guess it has some acid to "bite" the surface and the final layer will adhere better to that surface.
If the surface is prepared you just fill the final sealer into the tank and rotate it every direction to reach every "corner"
It looks like Brunox is a different story.
#8 stuart bowes
stuart bowes
  • 2,289 posts
Posted 11 July 2025 - 11:22 AM
gotta be honest looking at yours now I do want to cut mine open and clean it properly lol
I won't though, it's pretty clean (looking with a torch) and with my limited skills it'll be more risk of leaking (and looking wonky or something)
how did you cut it open anyway, and did you flush it first or steam it or anything
Edited by stuart bowes, 11 July 2025 - 11:23 AM.
#9 sonscar
sonscar
  • 3,084 posts
Posted 11 July 2025 - 12:27 PM
My tr7 tank suffered badly from rust.I used a tank sealer kit ethanol proof from a UK firm Rustbusters.Twelve years later it is still good.No cutting open was involved.It was reasonably expensive and if a tr7 tank cost the same as a mini tank I would have bought new.Just my experience.Steve..
#10 nicklouse
  • 18,767 posts
Posted 11 July 2025 - 12:30 PM
Some reading and products
https://www.frost.co...TxoCLJIQAvD_BwE
ps Brunox and petrol. Not sure. I seem to remember using petrol to clean it up.
Edited by nicklouse, 11 July 2025 - 12:32 PM.
#11 weef
weef
  • 511 posts
Posted 11 July 2025 - 12:41 PM
Thats a good job cleaning up the tank ready to weld together.
I don't know what method you are going to use to weld it back together, TIG, MIG or OXY /ACC,  TiIG would be best if you have it.
In any case getting to the practicalities of welding it, on the half without the origonal seam I would plug weld a strip, maybe 30mm wide and 1.5mm thick, right round the inside of the cut to form a lip that can be pushed into the other half, just like a tin lid, this will accurately locate the two halves and allow you to leave a small gap between the edges to ensure complete penetration. when welding.
The lip will locate the two edges together and prevents them from moving / distorting when welding.
#12 Spider
  • 15,250 posts
Posted 11 July 2025 - 05:55 PM
To be honest here, I feel cutting a tank apart to clean it makes for a lot more work.
If the tank is sound enough, but has some rust on the inside, there's a whole host of chemicals available these days that can be used to clean them up, or another popular method is if you can get a hold of a cement mixer, wire the tank to that, so you can tumble the tank, fit an old sender, put 2 handful of 5 and 10 mm gravel in it, an old cap on, and let it run for about 2 - 3 minutes, have a look inside to see how it's cleaning up, usually within 10 minutes it'll be done.
I'd also suggest removing the gauze filter that's in the tank. If you want a 'filter' here, fit an external one, at least then it'll be serviceable.
Then clean it out, fresh water will be OK, use a POR15 Kit and follow the instructions to the letter, even here, the cement mixer is handy as you need to tumble the tank over and over and over,,,, The tanks I do are usually new and clean of rust, so I use an engine stand to tumble the tanks for the POR15 process. One thing I'll add here is don't under estimate the time this will all take.
The Tank halves are resistance welded together originally. Any rust that resides in the seem here, the preparation chemicals in these fuel tank repair kits will deal with that. I find with the POR15 Kits, they have available one that's size to do motorcycle fuel tanks, that's fine to do one Mini (or Moke) fuel tank. If you follow the instructions, you'll get 20+ years from the tank, as long as the outside is in good order.
Don't forget to blow out the breather and fuel take off pipes as the last part of this process !
#13 gaspen
gaspen
  • 1,003 posts
Posted 11 July 2025 - 05:57 PM
This crap was sticked on the bottom. It was 2-3 cm thick and dense. It would take ages to remove it without cut the tank.
Also the bracket of the pipe gone but I've spotted an other one. I discarded the blocked filter also.
Anyway I will buy a POR15 kit and take a try
Attached File  20250711_124939 (1).jpg   61.2K   2 downloads
Attached File  20250709_172103.jpg   78.66K   1 downloads
#14 gaspen
gaspen
  • 1,003 posts
Posted 11 July 2025 - 06:41 PM
I don't know how dense the sealer is but I'm afraid that it won't flow under the strip
#15 gaspen
gaspen
  • 1,003 posts
Posted 17 July 2025 - 02:49 PM
I have a new idea  :proud:
If I would weld the two halves together It would distort and I won't be able to straighten it.
So I'll still cut the factory line-welding whichafter I weld back the flange. Then I weld it where I've cut it and I can straighten it
After that I "re-produce" the factory welding with my spot welder with a pair of straight electrodes. POR15 will seal the joint
Sounds good ?
Yes it is more work but I am not in a hurry  :D
