Edited by yukonphil, Yesterday, 06:16 PM.
Posted Yesterday, 06:06 PM
Posted Yesterday, 06:46 PM
Can you fit the fan on the outside of the radiator as that is where later Minis had there electric fan....remember because most Minis have transverse engines with a side mounted rad the fan sucks hot air out from the engine compartment and out under the front wing/wheelarch.
You could maybe ask Minispares for the overall depth of their electric fan:-
https://www.minispar...rpose-suck-type
The very last MPi classic Minis had a conventional front mounted rad with electric fan which might be better with an inline Morris Minor engine?
https://www.minispar...yman/pgg100890z
Edited by mab01uk, Yesterday, 06:59 PM.
Posted Yesterday, 07:49 PM
A mechanical fan might fit. But on and fit it correctly. Smooth side to the engine.
Posted Yesterday, 08:20 PM
A fan from a Mini is no good on a Moggy as it's reverse pitched from what you need.
Respectfully, I'd say you have other issues here, while I have misgivings about your cooling system set up, I'd say the root of the issue isn't lack of cooling but one that the engine is simply making too much heat.
Posted Yesterday, 08:28 PM
Posted Yesterday, 08:30 PM
Yep, I realise this but most fans will be reversible and I'm also seeing if anyone has made one. Like I say, it does currently work, I'm looking to find tune it to where I'd like it to be. Thanks though.A fan from a Mini is no good on a Moggy as it's reverse pitched from what you need.
Edited by yukonphil, Yesterday, 08:32 PM.
Posted Yesterday, 11:04 PM
Posted Today, 12:55 AM
Yep, I realise this but most fans will be reversible ,,,,
It'll only give reverse air flow if it us spun it in reverse.
This is a Fan for a North-south Engine
and from an East West from the engine side
and from the Radiator side
I hope you can see here flipping it over doesn't get you where you need to be,
Posted Today, 07:00 AM
Posted Today, 07:44 AM
Edited by 68+86auto, Today, 07:46 AM.
Posted Today, 08:08 AM
Posted Today, 11:15 AM
A picture of the environment? Picture of the car? Space limitations?
things to remember. Alloy rads are not better than brass/copper. Silver is worse than black at radiation heat. Most electric fans are either push through or pull through few are good for both.
Posted Today, 12:11 PM
Edited by yukonphil, Today, 12:16 PM.
Posted Today, 12:28 PM
Posted Today, 12:47 PM
Edited by yukonphil, Today, 12:48 PM.
