Mini Cooling Fan
#31
Posted 19 July 2025 - 05:54 PM
#32
Posted 19 July 2025 - 05:55 PM
#33
Posted 19 July 2025 - 06:27 PM
By the sounds of it now, you have well enough cooling capacity, but the engine is making too much heat
Common causes for this can be either the fueling and / or ignition requirements are not correct.
#34
Posted 19 July 2025 - 07:00 PM
#35
Posted 19 July 2025 - 07:01 PM
#36
Posted 19 July 2025 - 07:31 PM
Hi,
#37
Posted 19 July 2025 - 08:34 PM
#38
Posted 19 July 2025 - 09:29 PM
Thanks Spider. I thought I had the timing about right, basically just rotated the dizzy until the engine note changed then back ever so slightly. Will try backing it off a bit, mixture seems perfect looking at the plugs.
You really need to use a timing light and check the timing throughout the rpm range. Alternatively get the distributor tested and set the timing at one speed based on having a known advance curve.
#39
Posted 19 July 2025 - 10:49 PM
I think a refrain from the cooling side of things, a check and verify on the timing side of things and hope for some lovely riding weather is warranted.
At a later stage if curiosity gets to you - you may want to explore the distance the mechanical fan is away from the radiator and whether or not the cowl and or shroud could alter things.
Different people have different opinions on whether the shroud in particular works ( but this is mostly in the East west out the wheel arch placement).
My personal preference is for quite a good bit of the fan blades under the cowl - but obviously a gap to the radiator - and something like the 2 inch rubber stripping (shroud) sort of helping push all of the fan's air through the radiator not around.
Given your atypical arrangements - you may be limited to options but perhaps still worth mulling over if you are still not convinced you have sorted it.
#40
Posted 20 July 2025 - 06:01 AM
#41
Posted 20 July 2025 - 08:10 AM
Sorry, I should have been a bit clearer here.
Put another way (and as 68-86 was also suggesting), is it the correct distributor for the engine specification ? Likewise for the Carb needle and spring ?
You can set the timing at idle, same with the fuel mixture, but whether that's correct at various engine loads and speeds ??
There's a bit more on distributor advance curves here;-
https://www.theminif...d-distributors/
#42
Posted 20 July 2025 - 10:06 AM
#43
Posted 20 July 2025 - 10:07 AM
#44
Posted 20 July 2025 - 12:22 PM
If it's holding a steady cruising temperature I'd expect that is whatever temperature the thermostat opens at - regardless of what the gauge says.
#45
Posted 20 July 2025 - 12:39 PM
ThanksIf it's holding a steady cruising temperature I'd expect that is whatever the thermostat opens at.
Edited by yukonphil, 20 July 2025 - 03:38 PM.
