Valve Spring Retainers
2 replies to this topic
#1 Homersimpson
Homersimpson
  • 840 posts
Posted Yesterday, 08:03 PM
Hi,
I'm continuing the rebuild of a Morris Minor 1098 engine, for some reason it came with a CAM4810 cylinder head rather than a 12G202.
I have a 12G202 missing its exhaust valves as I borrowed them for another head years ago, otherwise the head is sound.
I've used the exhaust valves from the CAM4810 and also plan to use all the springs, however, I noticed when stripping it that the valve springs were slightly off to one compared to the retainers in some instances.
Upon stripping I've found that the spring retainers aren't a dead fit on the springs, compairing them to the retainers I have from the 12G202 which fit better.
Looking at the ones off the CAM4180 head the machined rebate is large allowing a bit of sideways movement.  They don't seem to move enough to come off but is it meant to be like this?
I have 7 of the type with the larger rebate from the CAM 4180 and 4 of the smaller rebate type (1 from the CAM4180 and 3 from the 12G202 which only had 3).
I've looked through the archives and found some info about different collet types but both seem to fit the single grove collets ok so I'm a bit confused, any idea why they are different and if they will be ok?
#2 Spider
  • 15,123 posts
Posted Yesterday, 08:26 PM
Bare with me here,,,,
The Valve Stems dictate which Collets are used.
The Collets dictate with Valve Spring Tops are used as they have different angles and diameters.
The Spring Tops then dictate which Springs can be fitted.
The other thing to check is Valve Stem lengths. It's been a while since I played with small bore stuff and I can't recall if there's different stem lengths here between head types.
#3 Homersimpson
Homersimpson
  • 840 posts
Posted Today, 06:31 PM
Thanks Spider, the valves I have are single groove, the collets are the same.
The spring caps are odd as I have now found I have three types, the ones that fit the valve springs nicely have a flat top with a groove machined around them in the top, one type is loose on the springs and has a raised centre which from what I've read is for the three groove collets.
The remainder are flat on top and don't fit the springs well, I'm struggling to buy some more as the pictures show them as being just flat on top and so I'm concerned they might be the same as the ones I have.
I assume the spring cap should be a good fit on the spring and not able to move side to side 1mm or so?
Edited by Homersimpson, Today, 06:32 PM.
