Valve Timing
Propshaft
, Jul 25 2025 05:11 AM
3 replies to this topic
Posted 25 July 2025 - 05:11 AM
With the cylinder head off how do you find the correct t d c for no1 cylinder
Posted 25 July 2025 - 05:27 AM
One way is to put pushrods back in to No. 1 Cyl Exhaust and Inlet. These will both be at their lowest when the piston is up and both will be up (one more than the other) when you're on the tail end of the exhaust / start of the inlet strokes. They only move around 1/4" - 5/16" here in total.
Posted 25 July 2025 - 09:50 AM
So set the valve timing when the inlet stroke is just starting
Posted 25 July 2025 - 10:15 AM
No. 1 TDC is when it's firing.
Both Valves will be closed for that.
