Front Suspension Bushes
9 replies to this topic
#1 pete l
pete l
  • 1,404 posts
Posted Yesterday, 05:37 AM
Hi all,
I need new front bottom arm bushes but can only find these
https://www.thelittl...-anciennes.html
They're different to my originals which are T shaped.
Will these work?
Pete
#2 nicklouse
  • 18,718 posts
Posted Yesterday, 05:44 AM
Like these for a pre 66 build?
https://www.minispar...pered-hole-type
#3 pete l
pete l
  • 1,404 posts
Posted Yesterday, 06:24 AM
kimd of yes. But with bigger ends, the cotton reel part
#4 pete l
pete l
  • 1,404 posts
Posted Yesterday, 06:26 AM
Mine looks more like these
https://www.minispar...rected-geometry
#5 pete l
pete l
  • 1,404 posts
Posted Yesterday, 06:29 AM
Mines a 1997 MPI
Top hat brushes, mine has these fitted from factory.
#6 vanessafisk
vanessafisk
    Starting My Mini Up
  • 1 posts
Posted Yesterday, 07:42 AM
Sounds like your front suspension bushes need sorting!
If they’re worn or leaking, replacing them is the smart move. Many users on the Mini forums recommend Powerflex polyurethane or high‑IRHD rubber bushes—they last longer and offer better control. Just make sure to install them oriented correctly, as offset sleeves can affect geometry.
#7 pete l
pete l
  • 1,404 posts
Posted Yesterday, 07:48 AM
Here's a picture
#8 nicklouse
  • 18,718 posts
Posted Yesterday, 08:02 AM
So standard taper fit.
they deform in fitting.
this is what is fitted from the FACTORY.
https://www.minispar...sh-1967-onwards
#9 pete l
pete l
  • 1,404 posts
Posted Yesterday, 09:01 AM
Those are not the same as mine.
they will not deform and spread out leaving two little ears and writing on the side. Mine are definitely top hat bushes, from factory too.
#10 Spider
  • 15,192 posts
Posted Yesterday, 09:27 AM
The one's Nick has suggested are the correct ones. They take up that shape you see after being fitted ;D
