Cleaning Up A 10" Steel Mini Wheel
6 replies to this topic
#1 ac427
ac427
  • 689 posts
Posted Yesterday, 11:04 AM
To those who have cleaning up these wheel before. Is it best to hand sand the wheel?
If i go the power tool route route is the best sort of abrasive to use?
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,086 posts
  • Name: Neil
Posted Yesterday, 11:24 AM
Clean up as in remove rust or remove paint?? either way its probably better to get them media blasted if they have no tyres fitted.
If the tyres are still on then i would use a twisted wire cup on a grinder to remove the worst then maybe hand sand after to get into the gaps etc.
#3 ac427
ac427
  • 689 posts
Posted Yesterday, 11:31 AM
Thanks, It's just a bare wheel with a some surface rust and remaining silver paint.
#4 alpder
alpder
  • 446 posts
  • Local Club: MCR
Posted Yesterday, 11:40 AM
I get mine sand-blasted and powder-coated by a local small powder-coat specialist. Set of five 10" steel wheels £100, including two coats of powder (base and top). No-brainer, compared to hours grinding with a wire wheel, rust and old brake dust in your hair, followed by Hope-erite Smooth which'll show the brush-strokes from day 1 and the start of new rust by day 100.
Always sets your teeth on edge, tho, watching the balance-weights go on later.
#5 stuart bowes
stuart bowes
  • 2,255 posts
Posted Yesterday, 12:01 PM
If the tyres are off already definitely want to focus on the sealing area on the inside of the lip, give that a really good wirebrushing all the way around both edges on each, give it the best chance of actually sealing when they put the new rubber on.  arguably the most important bit to sort out, before the cosmetic side of things.  Tyre fitter probably won't bother (unless you happen to know a good one)
If doing myself I'd use a drill with a wirebrush attachment, unlikely you'll do any damage to steel that way
saying that I would now go the sandblasting route having prepped and painted a few sets myself, the cost of the paint and all the agro doing it, paying someone to do it right is definitely better
Edited by stuart bowes, Yesterday, 01:45 PM.
#6 ac427
ac427
  • 689 posts
Posted Yesterday, 12:05 PM
Thanks, Would you go the powdercoat route as suggested above?
#7 stuart bowes
stuart bowes
  • 2,255 posts
Posted Yesterday, 12:21 PM
I probably would yeah, just a nice good finish, easy to clean, and to be fair the cost of that isn't really so bad when you look at the price of decent spray paint and wet n dry, and your time and effort etc
usually they have a spare set of wheels you borrow while they do it but being 10" I'd ring up first and check that.  the logistics of swapping wheels around can be a bit of a pain in the arse obviously
Edited by stuart bowes, Yesterday, 01:46 PM.
