Knuckle Joints Wont Fit Into Top Arms
Best Answer Bobbins , Yesterday, 06:19 PM
You’re trying with two cups …
Remove the cup from the joint or remove the one you have in the top arm. Go to the full post
4 replies to this topic
#1 mattaebersold
mattaebersold
  • 46 posts
Posted Yesterday, 06:10 PM
Hey I'm having a technical issue trying to get the knuckle joints fitted to the top arm. I have the arms out on the table, and I pressed in the cups. I understand that the cups act as a lip for the boot to catch on.
But my issue is that I cannot get the joints pressed in, there is no space when the cup is in there. I tried a heat gun to soften the plastic, but that had no effect. Am I missing something obvious here?
I bought these knuckles
Attached are a couple images
#2 Bobbins
Bobbins
  • 1,520 posts
Posted Yesterday, 06:19 PM   Best Answer
Edited by Bobbins, Yesterday, 06:19 PM.
#3 nicklouse
  • 18,718 posts
Posted Yesterday, 06:44 PM
As above take out the part that is already fitted.
maybe get a workshop manual as well.
#4 stuart bowes
stuart bowes
  • 2,255 posts
Posted Yesterday, 07:18 PM
it may not be immediately obvious, new knuckles come with one pre-fitted.  the replacement cups are if you want to keep the old knuckle
I'll be honest I nearly did exactly the same, ordered new knuckles and new cups, then realised when checking fitment
#5 mattaebersold
mattaebersold
  • 46 posts
Posted Yesterday, 09:18 PM
Well you are totally right, The kit came with spare cups, so I assumed incorrectly they were needed. Appreciate this thank you.
