Mpi Ecu
3 replies to this topic
#1 Shovey
Shovey
    Starting My Mini Up
  • 3 posts
Posted 28 July 2025 - 08:35 PM
Hi..I have a 97 MPi and it has started to run rough and also the fan seems to run again almost all the time and it backfires sort off.
I've seen the PSCAN reader that you can buy to plug in the ECU.
Has anyone used this kit ? Do they work will I be able to work out the issue by buying one ?
Any advice or tips appreciated
Jon
#2 mab01uk
mab01uk
  • 12,563 posts
Posted 28 July 2025 - 10:45 PM
You might find the link below useful.
Mini Mpi Diagnostics - Car Mechanics Magazine:-
https://www.theminif...anics-magazine/
Edited by mab01uk, 28 July 2025 - 10:46 PM.
#3 68+86auto
68+86auto
  • 1,025 posts
  • Local Club: Queensland Mini Car Club
Posted 28 July 2025 - 11:02 PM
They can be diagnosed the same way a carburetted mini can. No need to read the ECU. There may be some situations where it is required but in most cases it doesn't help at all.
Edited by 68+86auto, 28 July 2025 - 11:04 PM.
#4 Deeppockets
Deeppockets
  • 103 posts
Posted Yesterday, 10:39 PM
There is a lower cost options that may give you insight for the price of a cable.
I have succesfully used James Portman's RoverMEMS on an Andriod pad to find an intermittent fault on my intake temp sensor. It is worth noting that only easier vesrions work on my older pad, upto v49.0.  This and other vesrions are available on Aptode repository.
There is also a Windows vesrions of the app which I have also used using the same USB cable.
