This is the first gearbox I've rebuilt despite having done just about every other Mini based job available in the last 40+ years! So I'd like suggestions regarding what parts and specialist tools I need?
The strip down is nearly complete, I'm just waiting on some more meaty circlip pliers that I've ordered following my last query, plus I also need one of the "3rd motion bearing removal" tools from Guessworks. John's website is currently showing them as pre-order so I might need to mock up something similar in the meantime.
I already have some parts such as a central oil pickup, but plan to renew the bearings (?), thrust washers, and clearly all the gaskets. At the same time I intend to fit a x-pin diff.
The gearbox had done around 55,000 miles and was suffering from the typical 2nd gear issue, difficulty selecting 2nd on the way up the box and would jump out of gear on the way down. Therefore which components do I need to correct this? Is it a "1st / 2nd gear synchro hub", or baulk rings, or both? I still find gearboxes a bit of black magic and need to get my head around what does what. Also selector forks? There was no sign of any debris in the oil.
Being aware there might be some expensive parts needed, rather than just buying a rebuild kit, if I can sensibly re-use any of the larger bearings it'll help to keep costs down a little. Everything will be going through an ultrasonic cleaner which will make it easier to check for any play when I reassemble the box.
The grubby bits ....
Gearbox nearly empty ...
And the first batch of cleaned bits, they look more worn photographed than they actually are and I'm very pleased with the result so far ...
Stu.
