4-Door Classic Minis (Plus A 5-Door Mini Project)
3 replies to this topic
#1 mab01uk
mab01uk
  • 12,568 posts
Posted Yesterday, 09:19 AM
This project might be the first 5-door classic Mini to be built?
https://www.instagra...GY2&img_index=1
But BMC built this 4-door Mini below back in 1962/63.
Concepts and Prototypes : Mini four-door.
"According to one ex-Austin apprentice who helped with the Mini’s 20th anniversary celebrations in 1979, when he was researching the Mini’s early life, he came across the above interesting image of a four-door Mini produced by the Longbridge engineering team as a possible upwards extension of the Mini saloon range. The four-door Mini in the image was built in 1962-1963 and, as can be seen from the accompanying image (note the gap between the rear wheelarch and the rear corner flange), it was based on the longer-wheelbase Mini van, Countryman, Traveller, Pick-up platform and was photographed at the Longbridge development shops behind Austin’s HQ, known by one and all as the Kremlin.
The fate of this car is unknown, but it almost certainly did not survive. There was a rather unfortunate policy at Longbridge of scrapping most ‘non-standard’ prototypes like this, so it probably didn’t survive very long, or was stuffed into one of the infamous tunnels and got burnt in the fire in the late-1980s.
John Pressnell said that Ron Dovey of the experimental body shop remembered the single running prototype. Consideration was also given to a long-wheelbase two-door saloon and it seems possible that a car was also built to that specification."
https://www.aronline...mini-four-door/
Edited by mab01uk, Yesterday, 09:31 AM.
#2 mab01uk
mab01uk
  • 12,568 posts
Posted Yesterday, 09:25 AM
BMW also had this classic Mini 4-door built to coincide with the launch of the 4-door F56 MINI (5-door if you include the rear hatch).
Mini-Mengers:-
https://www.mini-men...le/mini-4-door/
Quote from Autocar magazine:-
"BMW built a replica of an experimental four-door Mini that was constructed by Austin-Morris in the early 1960s. Based on period photos, the new car is based on a later-model Mini Classic. BMW design sources say the original four-door was built on the same stretched wheelbase as the Mini Van, which was launched in 1960. One version used standard Mini front doors, which were flipped and rear-hinged, while another version used a bespoke door design. Neither prototype survived when the company decided not to pursue the idea."
Some more 4-door Mini conversions in this thread linked below.
Mini Major 4 Door Mini ?
https://www.theminif...or-4-door-mini/
Edited by mab01uk, Yesterday, 09:29 AM.
#3 stuart bowes
stuart bowes
  • 2,263 posts
I don't like the shape of the rear hatch to be honest but I do love the concept and nice to see these mad things still happening
#4 mini-mad-mark
mini-mad-mark
  • 881 posts
  • Local Club: northants wot no brakes
Posted Yesterday, 05:43 PM
I like the fact they've kept the standard length, most others are extended to use a standard door (turned 180 degrees I guess)
I'm not a big fan of the shape of the hatch either, but I'm guessing there was a need to have a bit more C pillar as there isn't much by the rear door
