Allegro Cv With Pot Joint?
2 replies to this topic
#1 CdnAustinAmerica
CdnAustinAmerica
  • 56 posts
Posted 05 August 2025 - 01:07 AM
I was wondering if there ever was a driveshaft where one could use the bigger Allegro CV with pot joints? I see on minispares you can use them with the hardy spicer type driveshaft. I was just wondering.
These CVs just don't seem to last long - converted to discs this spring - all new hardware for that - have an issue where my CV starts to click on/off throttle and slowly worsens to in turns as well. already gone through a set!
#2 nicklouse
  • 18,752 posts
Posted 05 August 2025 - 06:59 AM
The outer CV end is the same whatever driveshafts you use.
and as pointed out below you do need the correct driveshafts due to the different splines.
Edited by nicklouse, 05 August 2025 - 11:30 AM.
#3 GraemeC
GraemeC
  • 7,451 posts
Posted 05 August 2025 - 11:14 AM
Allegro CVs need a special shaft as the splines are larger.
As far as I am aware no one produes a pot joint shaft with the All-aggro splines on the outer end. There's be littel point as it would just shift the weak point of the shaft.
It is a very old school mod that is rarely done these days, even in top tarmac rally cars that were known for breaking shafts.
