A+ Engine And Any Rod Change Gearbox?
Best Answer nicklouse , 15 August 2025 - 06:17 PM
You can fit any gearbox to any engine. Some very early ones will have issues with a 1275 as the rods can catch the casing.
the issue you have to use if the correct transfer case to match the gearbox due to remote and early Rod using a smaller bearing than the later Rod gearboxes.
No such thing as A+ gearboxes.
Go to the full post
Posted 15 August 2025 - 06:13 PM
Posted 15 August 2025 - 06:17 PM Best Answer
Posted 15 August 2025 - 06:45 PM
