Have just bought a 97 sportspack and see it has adjustable tie bars on the front. i have noticed the car pulls to the left slightly on harsh braking. The braking system has been checked and all ok, could the issue be adjustable tie rods. What length are standard bars this will then give me an idea if these are way out. Going down the road the car runs straight. Front brakes are all ok have not checked rears. Thanks
From the evidence you give :
1. The car steers straight when not braking
2. The car pulls to the left under harsh braking
From the above I would suspect and check the rear brakes before spending any time on the suspension. Each rear wheel drum brake contains a hydraulic cylinder containing two pistons each operating a brake shoe. The pistons can seize or leak fluid if not regularly used and it may be , as you have just bought the car, that it has been standing for some time. This may well be a long standing fault with the car , the previous owner having not operated the brakes 'harshly' or if they had , then tolerated the 'pulling'. It's a couple of hours at most to check the rear brakes and if all good, then move on to front wheel steering measurements. The checks do require some mechanical expertise and tools so if that is something you want to do but are unsure of the level of difficulty, then post again on here.
Edited by rww, 16 August 2025 - 11:05 AM.
