Cold Air Under Left Wing Tubing
20 replies to this topic
#1 pete l
pete l
  • 1,415 posts
Posted 16 August 2025 - 01:09 PM
Hi all,
Putting the cold air tubing in under the left wing and I think I'm missing a part.
The ducting that goes from the front panel is a lot smaller than the dashboard connection, the inner wing bit. Is there an adapter that should be here?
Thanks. If anyone has photos 👍
Pete
#2 mab01uk
mab01uk
  • 12,621 posts
Posted 16 August 2025 - 01:53 PM
Fresh air and demister ducts 1969 on:-
https://www.somerfor...r-ducts-1969-on
Edited by mab01uk, 16 August 2025 - 01:53 PM.
#3 pete l
pete l
  • 1,415 posts
Posted 16 August 2025 - 03:16 PM
Thanks but that only shows a jubilee clip
#4 sonscar
sonscar
  • 3,082 posts
Posted 16 August 2025 - 03:44 PM
On my 1989 car the pipe fits over both the eyeball vent and the grille scoop.Steve..
#5 Steve220
Steve220
  • 5,084 posts
  • Local Club: BMC
Posted 16 August 2025 - 07:54 PM
Yeh, it just pushes inside the housing.
#6 mab01uk
mab01uk
  • 12,621 posts
Posted 16 August 2025 - 09:21 PM
Is the hose the same diameter both ends....would it work if ends were reversed?
#7 Designer
Designer
  • 640 posts
  • Local Club: LSMOC
Posted 17 August 2025 - 04:40 AM
Hi,
In your picture does the black fitting that is fixed to the bulkhead have the same diameter on both sides.
Could you have fitted it the wrong way by mistake.
Paddy
#8 pete l
pete l
  • 1,415 posts
Posted 17 August 2025 - 05:48 AM
The hose has the same diameter both ends and so do the parts screwed to the bulkhead inner wing.
There must be something missing, I can't remember how it was when I removed it.
#9 MikeRotherham
MikeRotherham
  • 994 posts
Posted 17 August 2025 - 10:25 AM
Does the narrow hose not push iINSIDE the back of the eyeball vent instead of over it like the wider hose?
#10 pete l
pete l
  • 1,415 posts
Posted 17 August 2025 - 10:38 AM
It will go in, but it's not tight and flops around.
#11 Ethel
  • 26,159 posts
Posted 17 August 2025 - 11:55 AM
As I remember them the hose  pushed over at both ends. The bit on the bulkhead also had a bayonet style socket to attach the vent, so it can't be back to front if it has the same.
From Mab's link the only part that changed was the scoop at the front end. It would seem a better place to risk a leak than in to the dash: if the other hose end goes over the inner wing fitting.
#12 mab01uk
mab01uk
  • 12,621 posts
Posted 17 August 2025 - 12:51 PM
Found this photo online which may help....
#13 pete l
pete l
  • 1,415 posts
Posted 17 August 2025 - 02:32 PM
That tube is much wider than mine. That one will fit straight over the air vent.
#14 Ethel
  • 26,159 posts
Posted 17 August 2025 - 02:43 PM
That'll be a late 80s Mini, going by the  side repeater.
This is the other option https://www.minispar...air-vent-nozzle
#15 mab01uk
mab01uk
  • 12,621 posts
Posted 17 August 2025 - 03:16 PM
What year is your Mini as some part number listings say there is pre and post injection Mini LH air hose (18 in diagram below) ?
I am guessing the later hose and grille intake plastic duct/intake (linked above by Ethel) may be a different size to clear the electric fan, underwing expansion tank, etc?
CLASSIC MINI AIR INTAKE L.H INJECTION:-
https://www.plminish...BSABEgIG0PD_BwE
Edited by mab01uk, 17 August 2025 - 03:21 PM.
