I've never known a fuel filler hole rot out before!
Do I put a chop in (if I can get one) or fill over it again?
Posted Today, 05:30 PM
Posted Today, 05:54 PM
Not a structural point, if the patch is welded in more or less OK, then leave it, fill over it again.
Posted Today, 07:21 PM
I`ve seen quite a few rot there and all have been late 80`s onwards.
I butt weld a piece in and dress it out both sides so you never know it was there.
Posted Today, 07:23 PM
This one's an 87 and has rotted out in some strange places like just under the guttering above the rear window.I`ve seen quite a few rot there and all have been late 80`s onwards.
Edited by Gaz66, Today, 07:25 PM.
Posted Today, 08:24 PM
Condensation from the boot can rot the parcel shelf and window aperture particularly at the bottom of the rear window and the top isn`t helped by the foam strips they seem to put in for no other reason than to trap condensation so it`s a good idea to remove them all.
Also worth checking the upper rear seatbelt mounting areas but it looks like yours is stripped of all it`s trim and remove the foam from the corners of the roof while you`re at it, you can get your fingers in without removing the headlining.
Posted Today, 08:37 PM
0 members, 6 guests, 0 anonymous users
