Hi all,
Problem is my distributor is 180 degrees out, which makes the HT leads look a mess. Can I just remove and turn 180 deg, my worry is dropping the drive peg.gear off the cam that drives the dizzy into the gearbox or is this not possible ?
Posted 25 August 2025 - 08:43 PM
Hi all,
Posted Yesterday, 01:02 AM
Removing the distributor has no risk of dropping the drive. If the drive on the distributor is installed wrong simply punch out the pin and rotate it. It is common for the Chinese ones to be like this. If you need to remove the drive that's in the engine, that's when there's a risk.
Edited by 68+86auto, Yesterday, 01:02 AM.
Posted Yesterday, 01:17 AM
Hi, thanks for the reply. It's an Aldon distributor. So I should be able to pull the distributor out without the drive coming with it ?
When I did this on my old engine the drive came out with the distributor so how would I prevent this from turning as the distributor is pulled out.
Posted Yesterday, 04:26 AM
I have never had that happen.
Posted Yesterday, 09:53 AM
