Innova 5568
20 replies to this topic
#16 Rubbershorts
Rubbershorts
  • 677 posts
Posted 09 September 2025 - 03:11 PM
Thanks Alpder, I can have an issue with mine when measuring advance timing. It flashes in two areas showing the timing mark twice. You can work out which one you need to go with but I'd rather it didn't do it. Been told by clever people it's some electrical interference from my car. Maybe this is the answer (substituting the no 1 lead). Daz.
#17 timmy850
timmy850
  • 3,560 posts
  • Local Club: MITG
Posted 09 September 2025 - 10:18 PM
I’ve had the 3568 Innova light for nearly 10 years and haven’t had any issues with it
#18 68+86auto
68+86auto
  • 1,344 posts
  • Local Club: Queensland Mini Car Club
Posted 09 September 2025 - 11:07 PM
The dwell reading is a diagnostic tool when used on electronic ignitions. Basic electronic ignition modules shouldn't vary the dwell so any variation is a sign of failure. The better ignition systems vary the dwell - increasing it as the RPM increases in order to saturate the coil but no more. If the dwell doesn't change correctly it identifies a failed module. They will often continue to run but very poorly so the dwell is used to identify a module failure.
I have the 5568 and haven't found any compatibility issues except for one time when I was doing a system with copper cored leads. It was intermittently doing random things but would work half the time.
Edited by 68+86auto, 09 September 2025 - 11:08 PM.
#19 PoolGuy
PoolGuy
  • 975 posts
Posted 10 September 2025 - 08:09 AM
Snap, had mine for 5 or 6, just works.
#20 Midas Mk1
Midas Mk1
  • 5,823 posts
  • Local Club: S.U.N.M.C
Posted 10 September 2025 - 06:40 PM
What leads do you have? have you tried swapping out?
ive found even with new cheap leads it can cause scatter like behaviour as above even with a known good snap on or gunson strobe. Fitting a better known good set of leads has resolved this when I’ve ran into it at work.
Edited by Midas Mk1, 10 September 2025 - 06:40 PM.
#21 Rubbershorts
Rubbershorts
  • 677 posts
Posted 11 September 2025 - 05:41 AM
You could be right Midas. It first did it with a set from Huddersfield mini spares. I now have a set of Power spark on. I had the car tuned by Mr Dodd so I haven't had any need to use the gun since, so not sure if these are any better. Fitting a new carb soon so might have to use it at some point. What would you be calling a good set? Daz.
