Hi everyone! Got to rebuild my classic mini engine, it is a 1275cc A+ engine from an Austin Allegro that has been bored out to +0.20, running standard gear set with 3.44 diferential
Engine is standard actually, as I know it does have the following:
- 1.3 rollers
- LCB exhaust manifold
- Maniflow exhaust
- MiniSpares inlet manifold
- HS4 carb running the stage one needle
Was running on a 123 distributor that stopped working and now running original distributor.
I would like to work out the best possible engine for my car, it is a 2025/2026 project so expect to hear from you before starting dissasembly.
Best regards,
