Pot Joints
2 replies to this topic
#1 Mark2390
Mark2390
  • 20 posts
Posted 01 September 2025 - 07:07 AM
Just a quick question before I start
Can both pot joints come out while engine is still on subframe ( looks a bit tight on the near side )
Only done them while engine was out
#2 nicklouse
  • 18,769 posts
Posted 01 September 2025 - 07:13 AM
IIRC only if you separate them if you want to remove them from the car completely.
Hole in subframe not big enough to pass the “pot” through.
#3 Spider
  • 15,253 posts
Posted 01 September 2025 - 09:22 AM
With the engine fitted, you can remove both joints as an assembly.
