Graunching & Clicking Sound Since Replacing Steering Rack
amendonny
, Sep 14 2025 11:01 AM
4 replies to this topic
Posted 14 September 2025 - 11:01 AM
Hi,
I have a 1996 Mini Cooper 35 (SPI).
I recently lowered the front sub frame slightly and replaced the steering rack with a new one from Mini Spares as the old one had some play.
Everything is torqued back as it should be and car is driving fine - except there is now a light graunching & clicking sound coming from around the dashboard / toe board area. It only happens when car is moving... Rocking the car around doesn't trigger it and turning the steering doesn't cause it either.
Here is a video of it:
https://drive.google...ew?usp=drivesdk
I've inspected under the car and everything looks fine, also the sound doesn't happen when the wheels are turned by hand... So I suspect it must be something to do with the subframe or new rack?
Any help much appreciated! Thanks
Posted 14 September 2025 - 12:02 PM
Check the column is aligned correctly.
Posted 14 September 2025 - 06:38 PM
Now that you have your rack and steering column connected, loosen the two U clamps as you may have inadvertently put some misalignment in by not having everything aligned before you tightened it all.
Posted 14 September 2025 - 06:42 PM
After watching / listening to your video clip, I suspect the floor around the toeboard mounts for the subframe may be cracked.
Posted 19 September 2025 - 05:27 PM
Loosened the nearside subframe Tower bolt, rocked the car around a bit then re-tightened it.
The noise has stopped 🤷♂️
