New build engine. 1.3 roller rockers
Posted 19 September 2025 - 07:49 AM
Posted 19 September 2025 - 08:27 AM
What camshaft have you fitted ?
Posted 19 September 2025 - 08:58 AM
You need to check if the rockers are touching the inside of the rocker cover.
Posted 19 September 2025 - 10:28 AM
Posted 19 September 2025 - 10:54 AM
Edited by nicklouse, 19 September 2025 - 10:54 AM.
Posted 19 September 2025 - 10:56 AM
What cam? What rockers? What cover?
Swiftune sw8 cam. Med roller rockers 1.3 ratio. Standard tin type rocker cover but I try and opoull the rocker forward as much as possible when tightening to stop it hitting the rockers.
Posted 19 September 2025 - 11:35 AM
Edited by imack, 19 September 2025 - 11:40 AM.
Posted 19 September 2025 - 12:17 PM
What is a standard cover to you?
never had issues with standard steel (original) covers with 1:1.5 rockers.
take the cover off and repeat your stationary revving.
Posted 19 September 2025 - 12:29 PM
https://www.ebay.co....ASABEgLk3PD_BwE
this is the cover type, I’m running roller rockers but 1.3 ratio.
Posted 19 September 2025 - 12:41 PM
Should not be a problem.
Posted 19 September 2025 - 01:33 PM
Posted 19 September 2025 - 06:56 PM
Was the new cam fitted complete with the optional spring kit?
Posted 20 September 2025 - 09:30 AM
I`m guessing you followed the camshaft break in procedure for a good 20 minutes on initial start up
I always hate that bit as it seems wrong
Posted 20 September 2025 - 12:01 PM
Yes it has there road springs fitted.
Posted 20 September 2025 - 12:04 PM
Yep ran for twenty mins at 2k rpm
