Hi, I’m in Australia and I’ve recently bought a 1968 Mini Deluxe (a re-bodied mk1 Cooper S) with a pretty warm 1330 in it. My question relates to coolant hose routing. It has a hose on the heater tap take off point which currently goes down to the bottom radiator hose. I realise this may be detrimental to the engine temp in very hot conditions which we see here. I have heard that routing this hose into the top of the thermostat will help this slightly. Looks like a MG Metro style sandwich plate is a good solution. But I’m not sure which one I need eg temp hole drilled or not (might be an option for running an electric fan one day), which way does the outlet point? And will having one affect the radiator bracket or will it need modifications? There is one with a stud hole for the radiator bracket or one with the threaded sender hole, but not both.
If I require more cooling, I thought about running the bypass hose round the front of the engine and through a small heat exchanger and back to the top radiator hose.
Cheers everyone ☺️
Edited by Hpal, 31 October 2025 - 05:37 AM.
