Lots And Lots Of Oil Spewing From Timing Chain Engine Breather
Posted 11 December 2025 - 02:33 PM
Its a newly rebored engine...new pistons and all that jazz that was running fine untill the oil pump had a problem, so It got changed.
I've done a leak-down test and every thing looks ok
Any ideas would be greatly appreciated.
Posted 11 December 2025 - 03:11 PM
Who built if?
I would be pulling the engine.
Posted 11 December 2025 - 03:21 PM
Posted 11 December 2025 - 03:27 PM
Would need to know a bit more about what's happened since the car was last running fine, really. Including how did the pump fail, and how far was the engine stripped to replace it?
Oil usually spews because of excess crankcase pressure. If the oil pump failed, did bits break off and end up scoring the bores allowing excessive blowby? Or if the head came off for the fix, then maybe the replacement gasket has failed and pressurised oilways that way?
Posted 11 December 2025 - 03:49 PM
This may sound strange but the engine has never run better apparently from the oil thing. AFR showing around 14.3
Have done a leak-down test, no pots higher than 25% Loss. Compression test shows all at around 160psi.
Posted 11 December 2025 - 05:01 PM
Who built if?
I would be pulling the engine.[thats helpfull
Posted 11 December 2025 - 05:08 PM
Posted 11 December 2025 - 06:14 PM
Are you sure it is not leaking from the oil gallery drilling in the cylinder head at the corner near the fan.Steve..
Hi Nicklous,why should Ibe pulling the engine?
Posted 11 December 2025 - 06:21 PM
Definatly comming from breather. Started engine brought rpm up to 3.2 and watched it come through breather
Posted 11 December 2025 - 07:27 PM
Is there oil up on the rockers?
Were the cam bearings replaced?
Posted 11 December 2025 - 08:17 PM
c
Cam bearings replaced on engine rebuild 50 miles ago
Not sure about rockers?.... please elaborate
Posted 11 December 2025 - 08:56 PM
Plenty of scope for oil system shenanigans there, but don't see why it'd come out the breather - there's a bigger drain hole from the timing cover in to the crank case.
Misaligned rocker post oil ways, spun cam bearing...
