Sorry just get it pulled. You have problems that adding breathers to will not fix.
a quote from Mr Calver.
Another often asked about subject - engine breathers and what is needed. There are those that go the multiple drain-pipe sized option, may be multiple 1/2" breathers. The reason flagged up is to relieve crankcase pressure. This is one of Graham's personal race engines. Note the single 1/2" take off on the rocker cover. That's it. This engine produces very tasty power. Essentially, if you are experiencing a high.level of crankcase pressure, the piston rings are not sealing and you are giving away performance. Discuss.
